CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($99.88 @ OutletPC)
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard  ($68.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($94.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - Radeon RX 560 - 1024 2GB Gaming OC Video Card
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($33.57 @ OutletPC)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($38.98 @ Newegg)
Optical Drive: Lite-On - iHAS124-14 DVD/CD Writer  ($13.69 @ OutletPC)
Wireless Network Adapter: Rosewill - RNX-N180UBE USB 2.0 802.11b/g/n Wi-Fi Adapter  ($14.99 @ Amazon)
Total: $424.28
Generated by PCPartPicker 2018-04-05 22:43 EDT-0400
Opinons, the 560 should get by with the games I have and want to have.
Planning to get windows 10, a 120 ssd and 8 more gigs of ram.
https://linustechtips.com/topic/913452-first-pc-v2/
bad PSU, get a CX450M or coolermaster masterwatt instead. i'd also look at an i3 8100 and cheap H310 board instead since you're gonna use an rx 560.
https://linustechtips.com/topic/913452-first-pc-v2/#findComment-11212392
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/913452-first-pc-v2/#findComment-11212423
4 minutes ago, LixCoffee said:
So, I don't need to change to a i3 or a h310 but its just an option?
yeah.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($112.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($81.99 @ Newegg)
Case: Cougar - MG110-W MicroATX Mini Tower Case  ($39.99 @ Newegg Marketplace)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Wireless Network Adapter: Asus - PCE-AC55BT B1 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($34.76 @ OutletPC)
Other: ASRock H310M-DGS LGA 1151 (300 Series) Intel H310 SATA 6Gb/s USB 3.1 Micro ATX Intel Motherboard  ($61.98 @ Newegg)
Total: $432.08
Generated by PCPartPicker 2018-04-05 23:17 EDT-0400
https://linustechtips.com/topic/913452-first-pc-v2/#findComment-11212475
ive heard about the i3-8100 but I thought it would really be a downgrade with most expense seeing that the ryzen 2200g is 100$ with integrated graphics
the 8100 has a weaker iGPU, but it doesn't matter when you aren't gonna use it anyways while the CPU portion will perform better.
https://linustechtips.com/topic/913452-first-pc-v2/#findComment-11212507
