6 minutes ago, jamesrauser said:
I am wondering what the cheapest graphics card is that can play skyrim at 1080p 60fps and high settings.
The gtx 1060 or the gtx 1070.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/913336-gpu-help/#findComment-11211301
These, only if you're staying modern.
A GTX 780 and 970 perform just about the same as a 1060 3Gb. A 980Ti performs roughly the same as a 1070.
https://linustechtips.com/topic/913336-gpu-help/#findComment-11211336
Cheaper would be nice. Right now I play at 1360x768 low settings and I hit 60fps what I was wanting was best case scenario. I am willing to compromise a little 30fps at the lowest 760p or medium settings
https://linustechtips.com/topic/913336-gpu-help/#findComment-11214081
My GTX 780 has no problems at 1080p Medium is most games, except for PUBG.
https://linustechtips.com/topic/913336-gpu-help/#findComment-11214096
My GTX 960 2GB can run it at a near solid 60FPS but its VRAM is pretty much maxed so I'd try and get a 4gb card. Should be pretty easy to find used on eBay
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/913336-gpu-help/#findComment-11215123
  • 2 weeks later...
