Hey Guys!
Straight forward question, how much (approx) is my PC worth, as it is used.
i5-4460(Brand new)
Gtx 1060 3GB Palit model (very slightly used)
16GB corsair vengeance 1866Mhz (Brand New)
Chieftec Iarena 450W PSU (3 months old)
1TB 7.2K rpm Generic Toshiba hard drive
Cooler Master elite 241 case
Samsung DVD-writer
PC's been daily used, 1-2 hours every day.
would it be worth for me to sell this PC, along with the monitor (22" asus v228), and keyboard (15$ membrane keyboard, with backlighting), and buy a gaming laptop at around 700 pounds?
thanks for the answers in advance :D
https://linustechtips.com/topic/913290-how-much-is-it-worth/
I'm very bad with this, but no one else is here
I would say 500-600, in USD though. I would first look around for local selling and see how much a similar system goes for. Or you can just add up the individual new/used prices of the parts.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/913290-how-much-is-it-worth/#findComment-11211085
Generally I have found that custom built PCs make back more money if you part them out. If you're willing to go though the effort, find out what similar parts are going for used then price your parts accordingly. The lower you're willing to go generally the faster the parts sell but really would depend on demand.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/913290-how-much-is-it-worth/#findComment-11211114
you see, I'm not really in a hurry right now, but that will actually be the smartest of options I think.
https://linustechtips.com/topic/913290-how-much-is-it-worth/#findComment-11214192
