get a Pro4 or prime plus for the board, and a 2800-3200mhz stick for ram.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206332
Do you need a cooling solution? If so, air or water?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206364
Motherboard: Gigabyte - GA-AX370-Gaming ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: Team - Vulcan 32GB (2 x 16GB) DDR4-2400 Memory  ($209.99 @ Newegg)
Case: Corsair - Crystal 570X RGB (Black/Red) ATX Mid Tower Case  ($179.98 @ Amazon)
Total: $489.96
Generated by PCPartPicker 2018-04-04 10:29 EDT-0400
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206374
Total: $489.96
I love how he said 8gb min for ram and you maxed out his budget and got 2x16 xD
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206418
I could've gone 64gb and maxed his mobo out but that would've left no room for a decent case.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206427
Total: $489.96
Nononononono
Don't cheap out on the motherboard. The PRIME X370 Plus isn't that much more.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206502
Just now, JDE said:
Nononononono
The board I specified is good enough anyway.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206509
Good enough to run a 6 core at stock, or with a light overclock. Why compromise, instead of getting a more reasonable amount of RAM (that runs at a decent speed) and a decent motherboard?
Edited by seon123
Something something
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206529
1) RAM speed really doesn't make much of a difference.
2) "Light overclock" he doesn't even need that, he's upgrading to a ryzen 5 for crying out loud. It's gonna be quite a while before he even needs to overclock.
3) That is a decent motherboard. My friend has one and he runs a ryzen 7 1700x at 4.8ghz on that thing. Air cooling if you're wondering.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206540
RAM does make a quite significant difference on Ryzen, especially as the infinity fabric thing depends on the RAM speed.
Why would you give up the possibility to overclock properly just to get a silly amount of RAM? And if he decides to get a future gen 8 core, he won't be able to overclock it much.
It's an objectively crappy motherboard. It uses crappy components for the VRM. I seriously doubt has reached anywhere close to 4,8GHz. I don't know if you've noticed, but 4,2GHz is considered very good on Ryzen with water cooling, and unreachable for most chips.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206555
Where are you getting your information from? 32GB isn't a silly amount of RAM either, infact if you look at some games, you'll find some games can take up to 20GB of ram by themselves. 32GB also makes it so he doesn't have to upgrade his RAM for a long time. For the record, I've personally seen my friend's computer get up to 4.8.
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206565
sorry for the misunderstanding everyone but 500 dollars includes the cpu (ryzen 5). the motherboard needs to have a pci-e 16x and another atleast pci 1x (for wireless wifi card)
Edit: Stock cooler will work for anyone asking but a better one can help.
Also, would a 450w psu be enough with an EVGA GTX 1050 SC?
https://linustechtips.com/topic/912828-help-choose-upgrade/#findComment-11206940
