Will xbox kinect work with PC
Go to solution Solved by RollinLower,
is it the first or the second Kinect? windows has an article about this here -> https://www.windowscentral.com/you-can-now-use-kinect-and-windows-hello-log-windows-10
Hi!
So I got an Xbox one Kinect for like 5 bucks. I really don't know why did i bought it I don't own a Xbox one.I bought it because it was really cheap.But currently I don't have any use for it.I have a PC so can it be used for security options like Windows Hello or something Else?.If Yes can you please tell me how.Thank you.
https://linustechtips.com/topic/912405-will-xbox-kinect-work-with-pc/
Just now, StillSilver :( said:
It came with all adapters and other stuff.The seller gave me everything
So, if it already has an adapter to USB, just plug it in and see what it does.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
Hey Thanks for the article by the way I have the Kinect V2 I will try to figure it out how to use it
