G'day from Australia,
I'm planning on building a PC for my younger brother but was looking for some confirmation before I head off and go buy the parts. This computer was designed to be small since the area I'm working with is tiny, so I went with the "Silverstone - Sugo SG13WB" as it was nice and small but also good looking. I then went for the "Gigabyte - GA-AB350N-Gaming WIFI" which came with WiFi, which is a must since there are no nearby Ethernet ports, and Bluetooth for his headphones. This PC will be foreseeable just used for 1080p gaming with the budget being ideally around $1000 AUD. The rest of the parts is listed on https://au.pcpartpicker.com/list/hDZCbX. If you have any thoughts or recommendations please leave them below. Thanks so much for your time. :D
Note: This price should exclude monitor, OS and peripherals
https://linustechtips.com/topic/912277-shoebox-pc-help/
Do your brother a favor and chuck an SSD in there
https://linustechtips.com/topic/912277-shoebox-pc-help/#findComment-11200789
Desktop benching:
https://linustechtips.com/topic/912277-shoebox-pc-help/#findComment-11200931
