How much should I charge to build
Solved by Oshino Shinobu,
$100 and either charge for any help thereafter or explain that you're not responsible for every problem they have with it in the future.
From my experience, helping family, friends, neighbours etc. with computers sucks because they then end up coming to you for every little issue, acting like it's your fault. Because of that I pretty much only help with computers that are actually in the house unless it's a simple problem. For friends, I mostly point them in the right direction if it's something they can do themselves rather than doing it for them.
