Ok so i have a wd green(WD20EARX) 2tb and it doesnt work at all, windows crashes wile loading the drive, and if i dont click on it and use a drive scaner (HDD tune,HDD scan, and even segates tool) i cannot read the s.m.a.r.t wich is strange, i think that it is a pcb problem(wich im concidering buying) because the data is +\- important so yeah :)
PS: i´ve read on other forums that a pcb swap+ the bios chip it works. And the drive is from a wd my book essentials(and i have the usb-sata converter)
Here is the link for the donor hdd(https://www.ebay.com/itm/PCB-Controller-2060-771698-004-WD20EARX-00PASB0-Festplatten-Elektronik/182499059260?hash=item2a7dcaa63c:g:nrEAAOSwv0tVEYVR#shpCntId)
Edited by diogo_the_man
https://linustechtips.com/topic/912194-wd-hard-drive-problem/
Just now, Electronics Wizardy said:
Just restore backups and get a new drive.
If you need data send it to a lab, you have a better chance of getting data this way if its your only copy
Keep backups...
Thats just the problem i dont have any backups :( And sending it to a recovery lab is unrealy expencive (i know its the last resort) so thats why im asking if any one has ever tried this and it worked (if so that they would help me :))
https://linustechtips.com/topic/912194-wd-hard-drive-problem/#findComment-11199899
if it's the PCB and the one you replace it with matches then this will fix it. but the problem could be something else.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/912194-wd-hard-drive-problem/#findComment-11199911
20 hours ago, mihailc said:
Have you tried native WD program ? https://support.wdc.com/downloads.aspx?p=3&lang=en
(Be careful not to "write zeros" to your drive)
yes i have the drive shows up as read-only, and ive tried to repatition the drive withou any luck :(
https://linustechtips.com/topic/912194-wd-hard-drive-problem/#findComment-11206956
