So I recently got a i7 3770k and plan to overclock it as high as I can. to do that I am looking at new coolers to replace my hyper 212 LED, I am looking at a H100i or a Noctua NH-D15.
I have no idea if the D15 will fit in my case though, the 212 fits no problem but the D15 is huge, and I am having trouble finding specs on how big a cooler my case will take.
here are links for the case and coolers:
http://www.zalman.com/contents/products/view.html?no=362
https://noctua.at/en/nh-d15/specification
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-led/
https://www.corsair.com/ca/en/Categories/Products/Cooling/Dual-Radiator/Hydro-Series™-H100i-v2-Extreme-Performance-Liquid-CPU-Cooler/p/CW-9060025-WW
I think I will be using the Noctua NT H1 thermal paste
https://linustechtips.com/topic/912115-will-it-fit/
5 minutes ago, MatejNeumann said:
http://www.expertreviews.co.uk/pcs/pc-cases/53298/zalman-z9-plus-review
here they said that they managed to fit a 165 mm cooler in there. I so I guess that the noctua cooler would be a really tight fit
Thanks, I think it might be safer to get the water cooler xD or get a full size tower.
https://linustechtips.com/topic/912115-will-it-fit/#findComment-11199233
12 minutes ago, MatejNeumann said:
I've actually asked a similar question to yours and another member recommended this cooler to me http://www.scythe-eu.com/en/products/cpu-cooler/fuma.html.
It very similar to the noctua you posted except that it is a little bit cheaper and shorter about 150mm.
thanks for the recommendation, unfortunately I cant find any retailers in Canada and I dont think they ship to canada.
https://linustechtips.com/topic/912115-will-it-fit/#findComment-11199306
The NH-D14/D15 are both 160mm tall so it shouldn't be a tight fit at all.
@TArthur99
What ram do you have? The coolers fit the case just fine but you should make sure the ram isn't too tall.
https://linustechtips.com/topic/912115-will-it-fit/#findComment-11204635
@TArthur99
Well my mistake then sorry. I've been looking at this site and they must have misswritten it then
https://linustechtips.com/topic/912115-will-it-fit/#findComment-11205673
Yeah, the height without fan is wrong, should be 160mm.
This is nice "tool" if you have printer and case doesn't have compatibility listed anywhere CRYORIG CASE DEPTH CHECKER | Research Idea Gear
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/912115-will-it-fit/#findComment-11207013
