Hi all!
So i just built a computer for a friend, and being the thorough person that i am, im running some stress tests. What i have running is 3 instances of prime 95, along with firmark at 1680x1050 with 4x AA. Ive got monitors for both CPU and GPU temps and levels. BTW the gpu is a asus directcu II 770 2GB. Basically after i start firmark, the GPU temp rises steadily from around 33c to 75c. The cpu goes from around 25c to 60c and holds there. After a little while, screen goes black and i cant get it to come back without resetting the power. I even didnt run the prime95 to see if that would fix the problem, and nada still crashes. Im at a loss as to what is happening. I thought 75c was fine? What could be causing the problem, its a brand new windows 7 install all the latest drivers everything. It makes no sense. Ive got all the GPU plugs seated correctly and their little LEDs come on. Ive got a brand new 750w EVGA PSU. Its baffling me as to what is causing the issue.
I really need to get this issue resolved because its a christmas gift (no not from me from his parents).
EDIT:
Specs:
intel i7-4770k not OC
Kingston hyperx 3k
Asus z87-a latest bios
Asus Direct CU II 770 2GB
16gb ADATA ram
3tb WD red drive
750W EVGA PSU.
Cooler Master t4 cooler.
https://linustechtips.com/topic/91211-gtx-770-overheating/
System specs?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231122
System specs?
Sorry,
Intel i7-4770k
Kingston hyperx 3k
Asus z87-a
16gb ADATA ram
3tb WD red drive
750W EVGA PSU.
EDIT:
Just re-did the test and i got to 76c for a min or two before it my screen went black again.
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231133
hmmm, maybe drivers, faulty equipment? on those lines probably
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231154
Its not over heating that for sure. Bet your cpu is unstable.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231158
Also dont stress two things at once. Always do one if you have no clue what is breaking it.
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231246
Tried the card in my personal rig and had no problems. I used the driver asus provided...no luck in the new rig but fine in my rig. Im thinking either OS or MOBO issue. Ill try reloading the OS i think next.
Updated the GPU bios and i was able to get it to run around 80c for about 5-7min before it went out on me.
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1231868
Don't use furmark, unless you want to brick your card.
AMD Ryzen 5900x, Nvidia RTX 3080 (MSI Gaming X-trio), ASrock X570 Extreme4, 32GB Corsair Vengeance RGB @ 3200mhz CL16, Corsair MP600 1TB, Intel 660P 1TB, Corsair HX1000, Corsair 680x, Corsair H100i Platinum
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1232014
Prime95 and intel ix 4xxx "do not mix very well" (ask intel why)  <_<
so... in the good news, it may not be the 770  :)
for test only the 770 use Valley - the HD test  B)
ignore the cpu problem for now, when you get a new cpu bench you can start to retest that intel  :ph34r:
APU = A10
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1233324
U should Always use the driver from the website of Nvidia for drivers not the driver disk for a start :/
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1233553
And when i did that...it crashed. When i used the Driver on asus website it worked fine. I ran heaven benchmark and it seems to be all good. What should i use to stress the CPU?
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1233810
Prime95
Motherboard: MSI-990FXA-GD65 | CPU: AMD FX-8350 @ 4.3Ghz | CPU Cooler: Corsair H100 | RAM: 8GB Corsair Vengeance 1600Mhz | GPU: MSI GTX 770 Lightning @ 1300Mhz CC and 8000Mhz MC | Case: Fractal Design ARC Midi R2 | PSU: Corsair AX850 | OS: Windows 8.1
https://linustechtips.com/topic/91211-gtx-770-overheating/#findComment-1234267
  • 1 year later...
