So I recently just got my first job, Im 15 and Im looking for a PC that wasn't bought from bestbuy and is actually decent. I want you opinions please.
First paycheck is going to be around 300-400ish
CPU:AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor.- 93$
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard- 50$
RAM:Crucial - 8GB (1 x 8GB) DDR4-2400 Memory- 80$
GPU: EVGA - GeForce GTX 550 Ti 2GB Video Card (this was from my ex stepdad and It will run the games I play currently on high settings. ITS FREE)- FREE
STORAGE: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive-57$
POWER: Rosewill - 550W 80+ Bronze Certified ATX Power Supply- 34$
Optical Drive:Lite-On - iHAS124-14 DVD/CD Writer- 15$
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter- 21$
This combined is around 390-400. It will run a majority of my games. The 550 ti is outdated by a mile, but for what I want it will do. Im planning to upgrade later. Here are the other parts I want
Crucial - 4GB (1 x 4GB) DDR4-2400 Memory- 45$
Gigabyte - GeForce GTX 1050 2GB OC Video Card-160$
Leave opinions pleaseeeee
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/
Get at least 8GB of ram, google chrome will eat up 4GB with just a few tabs.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198311
I would get a more powerful power supply than you think you need. I had a 750W for my build but it blew up after about 5 months. Maybe go for a 650W instead
PC SPECS: i7 - 3820, 32GB GSkill DDR3 RAM, 2TB Seagate Hybrid Drive, Intel 240GB SSD, Corsair Spec Omega Case, Strix GTX 1060 6GB, Corsair H150i Pro RGB, Corsair CX850M PSU
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198316
Get B350 mobo instead, it allows overclocking. Avoid MSI ones due to inefficient VRMs.
Full name of PSU?
Dont add 4GB, add 8GB for further upgrade.
new Nvidia cards are coming this summer, so dont set your sights on the 1050.
Desktop benching:
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198325
He has. Read carefully.
Name of PSU and your system specs? A system like OP's wont draw more than 300w of power. Your PSU blowing up isnt always because of wattage.
Desktop benching:
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198327
Higher wattage doesn't mean better. His planned build nor his desired upgrades call for anything higher than 500W, so long as it's a good one.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198339
Ran on a system with 4gb ddr2 before and it handled WAYYYY more than that.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198353
8 minutes ago, LixCoffee said:
that is the full name of the psu, I added this up and it should only use around 300w... I don't really need a higher power supply.
The one thing you dont wanna cheap out on is the power supply. The best thing to do right now is wait until your next pay check, or buy higher end stuff and get a little bit at a time.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198380
a ryzen 2200G with a fast 2800-3200mhz kit will likely perform on par if not better than the 550ti, get the APU and sell off the 550ti for some extra cash or something. i'd get a corsair CX or coolermaster masterwatt instead of that psu.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198407
Imho, Buying a R3 1200 right now is wasting money when, for just 6$ more you can get the R3 2200G which not only performs better, but also has a built-in GPU that beats your 550Ti (although not by much).
Also, if you're buying a Ryzen system no matter which specific chip you're picking, do NOT buy a single RAM stick; Ryzen really likes fast RAM, so 2x4GB is definitely much preferred over 1x8GB. Also, try to buy RAM that runs at 3000 or 3200 Mhz.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198417
Just now, LixCoffee said:
if i upgrade to a 2200g, and if I keep the 550ti will it mess up my system?
nope, but kind of pointless keeping the 550ti around when the 2200G's iGPU would perform better anyways.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198462
15 minutes ago, LixCoffee said:
so its pretty much a better upgrade but tbh who is going to buy a 550ti thats 6 years old?
People who are looking for just one last component at a good price to put together another older system. For example, my spare R9 390 is overkill for the system I could piece together right now from parts laying around. I've even got all peripherals, monitor etc to go with it.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198531
Hey!
I do not think that you can squeeze much more from this budget. Take a look at this build with better psu, b350 mb chip (capable of oc). You will be able to play some games at 1080p 60hz it will perform similarly to your 550ti as mentioned above, if you manage to sell the 550ti and stretch your budget a little bit more go for 2400g. Ryzen loves fast ram so that is why 3000 mhz especially ryzen apus. Go for 2x4 GB as it gives you a little bit more performance compared to single channel.
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($99.88 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.49 @ SuperBiiz)
Memory: ADATA - XPG GAMMIX D10 8GB (2 x 4GB) DDR4-3000 Memory  ($90.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.21 @ OutletPC)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($9.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($38.99 @ Newegg)
Total: $357.55
Generated by PCPartPicker 2018-04-02 11:04 EDT-0400
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198536
there's always gonna be that one guy who needs a cheap display adaptor, something to fill up his GPU collection or whatever. see what they're going for in your aera and sell it at around that price.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11198540
So with the feedback i change couple things.
here is teh updated list
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor: 100$
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard 50$
GPU: Radeon RX Vega 8/GTX 550 Ti (til i sell it) 100$
Ram: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2400 Memory 81$
Hard drive: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive 60$
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case 34$
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply 30$
Wireless adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter 20$
Again Total is 390$
With planned upgrades will be a new graphics card when the next nvidia one comes out
and more ram probably 2 8 gigs.
https://linustechtips.com/topic/912049-first-pc-not-prebuilt/#findComment-11207043
