Hi,
My computer won't turn on after a few hardware swaps I did.
Parts :
MSI Z77 Mpower, i5 3570k @ 4.0 Ghz, ATI HD4870, Gskill sniper low voltage 2x4gb 1600Mhz, Samsung 840 series 256gb (os), 2x ST4000DM000 (raid 1).
So here's what I did. I shut down the computer, I disconnected every wire with caution to wait for CL_CMOS LED to turn off before pulling the cord. I then switched my ram for Gskill Ares 2x8Gb 1866Mhz (occupying DIMM slots 2 and 4, same ones as my previous ram sticks) and switched my GPU for Asus R9 280x DCUII.
I reconnected everything, CL_CMOS LED powered on. When I pushed the power button, nothing. I pushed and pushed again but nothing happens. I noticed that CL_CMOS LED turns off after I try to push the ON button on my case. When I switch the power off, the LED remains off until it flashes briefly and turns off again.
I've tried putting my old parts back in 1 by 1 but it won't turn on again.
old ram timings (CL9-9-9-24, 1.25V) new ram timings (CL10-11-10-30, 1.5V)
The lights on my new gpu's pcb were lit during this struggle. Power could come from the pcie adapters though.
Please help!
https://linustechtips.com/topic/91202-computer-wont-turn-on-help/
Nice copy and paste skills. Try Ctrl shift v to get rid of the back colors
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Whats the PSU rated at?
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
Check that all cables are tight and connected. And that ram is really isntalled. If your mobo has onboard power switch, try booting with it.
Didn't work. I checked everything power related, I cleared CMOS. I tried with only 1 ram stick in DIMM 2. Nothing. Now that I cleared  CMOS, the CL_CMOS led doesn't even turn on when the psu is connected.
Ok so I fixed the problem. I....don't want to tell what was the problem.
Thanks to everyone who helped.
Did you forget to plug it in?  :D
System: CPU: 4670k | Mobo: Gigabyte Z87MX D3H | RAM: 8gb 1600Mhz | Case:Corsair 350D | PSU: Corsair CX430, to be upgraded soon | GPU: HD4600, to be upgraded soon
Dogecoin: D787N1VP3JaK3wmKehWhqGXBvspZpQ4YFV
Damn it, I was gonna say that.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
you forgot to plug in the 8 pin cpu connector(?)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
The 24 pin connector was loose on the psu side. It doesn't lock in and click and is a little loose normally.
I figured it out after testing psu with multimeter (EVERY F***ING pin), after testing cpu on a friend's mobo and testing ram with memtest on that same mobo. Also, multiple assembling and disasembling of rig. I'm just going to play BF4 now. KTHXBY
