Hello Everyone,
I am searching for a cooler for my AMD FX6100 processor. Till now I was using the stock cooler that came with the processor. It has stopped working. Now I need a good cooler which is cheap. I won't be overclocking the CPU. Just normal use.
Can anyone suggest some good and cheap coolers.
Thank You
https://linustechtips.com/topic/911638-cooler-for-am3-socket/
Where are you shopping/located? What ram and case are you using?
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194788
6 minutes ago, Shreyans Suraliya said:
Hello Everyone,
Thank You
Hyper 212 EVO, just plain no frills. You could go cheaper, but this is still my go to cooler for stock and mild overclocks. Relatively quiet too.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194789
10 minutes ago, Shreyans Suraliya said:
Hello Everyone,
Thank You
I would go with a Hyper 212
They have been my Go to for most of my builds and i have recommended them to every person who's planning on a build. They are compatible almost every Socket and gives really good performance for its price, it can even push a mild OC if you want to.
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194800
Just now, Shreyans Suraliya said:
thank you. Will check the cooler. ?
Just make sure it fits as it's way taller than a stock AM3 cooler. But should fit in most ATX cases.
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194802
3 minutes ago, Shreyans Suraliya said:
In India. About my case, honestly I don't remember my case model number. RAM is a 4GB Kingston 1333MHZ.
If you're not sure what case you have, please post some photos of it. Could be more specific on the ram? There should be a model name besides the manufacturer's name.
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194805
Ok. I'll post some pics and check RAM model number.
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11194842
If RAM doesn't have heatspreaders, its most likely ValueRAM and will fit with every cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/911638-cooler-for-am3-socket/#findComment-11196109
