Probably not. These things most likely have their own protocols for communicating.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/911540-rgb-panel/#findComment-11193791
2 hours ago, Pangea2017 said:
Asus uses WS2812b and most other brands also. Why? they are cheap and good enough.
You have to mod the header also check the mobo manual that they have the same voltage (5v and 12v variants are aviable). Also make sure the header have enough ampere.
Ah ok, Thanks :)
https://linustechtips.com/topic/911540-rgb-panel/#findComment-11194047
