So, I'm pretty much 85% computer hardware illiterate, I know most things like what I need or what something does, but when it comes to putting the parts together and something going wrong, I'm completely lost.
Typically when I try to approach this problem I'll spend 2-3 hours configuring my computer trying to fix it, aka watching videos, reinstalling drivers, deleting old programs, reinstalling hardware, upgrading hardware ect.
The problem is FPS issues and stability. Most computers can run league of legends at a really good framerate so I'll use that as an example for my case.
When I'm playing the game will be at a stable 120 fps, but there's tears every 5-7 seconds where the fps drops to 80-90, and it will create a jitter on the screen where it kinda freezes for half a millisecond, it's noticeable while playing and quite annoying.
For the parts I have I know for a fact I should be running a lot of things better than they're actually running.
My brother told me before it might be a powersupply issue but before I get another I want to know what I should look for and what I should look for and if I should even get one
This is my hardware.
Operating System
    Windows 7 Ultimate 64-bit SP1
CPU
    AMD Phenom II X6 1090T    44 °C
    Thuban 45nm Technology
RAM
    12.0GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
Motherboard
    ASUSTeK Computer INC. M4A79T Deluxe (AM3)    51 °C
Graphics
    2260WG5 (1920x1080@60Hz)
    ASUS VH242H (1920x1080@60Hz)
    4095MB NVIDIA GeForce GTX 1050 Ti (ASUStek Computer Inc)    33 °C
Storage
    931GB Western Digital WDC WD10EZEX-08WN4A0 ATA Device (SATA)    29 °C
Optical Drives
    No optical disk drives detected
Audio
    Realtek High Definition Audio
Power Supply
   Pro 82+II (450W)
Anyone have any idea on what I should do?
Thanks a lot for reading
https://linustechtips.com/topic/911003-fps-and-tear-issues-software-or-hardware/
