Just now, Eatenjoe said:
but how would my mobo lights sync
If you're plugging the RGB hub into your mobo's RGB port, you should be able to sync them all in your motherboard's utility.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/910969-rgb-case-fan/#findComment-11188615
2 minutes ago, Eatenjoe said:
could i plug in a rgb spliter into the hub the hub has 4 slots i need 5 fans
Does your mobo have a second RGB header? Usually up by the CPU cooler
https://linustechtips.com/topic/910969-rgb-case-fan/#findComment-11188624
no
Might be skunked. I don't know if plugging a splitter into a hub is something you can do. Do you really need all five fans? Just some food for thought.
https://linustechtips.com/topic/910969-rgb-case-fan/#findComment-11188634
2 front 2 top 1 back
i ordered this case http://www.coolermaster.com/case/mid-tower/mastercase-h500p-mesh-white/
https://linustechtips.com/topic/910969-rgb-case-fan/#findComment-11188638
46 minutes ago, Eatenjoe said:
i need to be able to connect 5 cooler master rgb fans to motherboard rgb header,(msi Z270 gaming pro carbon) to sync to rgb lights how do i do this
For RGB control you can use splitters on the RGB header but note the amperage of the LED's for each fan as you must not exceed your max output of the RGB header.
https://linustechtips.com/topic/910969-rgb-case-fan/#findComment-11188687
