AIO Pump
Solved by xXCapAwesomeXx,
No, ended up tipping the system on its side and tightening the block, when the pump ran it made grinding noises like it was running dry or trying to run. Ended up ordering a new one
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
