Hi.I recently updated the android to the latest one and now my battery is getting lower in inactivity time.Especially on nights, it gets from 70% to 20%.There are no apps running in the background and i have no notifications , so the reason is unknown.Any solution for this?
https://linustechtips.com/topic/910395-battery-problem/
Reboot the phone? Worst case, one of your apps is causing a wakelock in the background which means you'll have to track it down or do a factory reset and rebuild.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/910395-battery-problem/#findComment-11183034
