Gaming CPU help
Solved by Spotty,
4 minutes ago, BioAlpha said:" i7 6700 LGA1151 CPU with 6 to 8 Cores."
The 6700/6700k is 4 physical cores with hyperthreading, giving a total of 8 threads.
The main difference between the 6700 and 6700k is the k version comes with higher clock speeds out of the box and can be overclocked as well.
If your friend was 6 cores, then he should look at the 8700k CPU.
