Case choice for 1st custom loop
Solved by TVwazhere,
5 minutes ago, 2PartAuthentication said:Just one last question - for cooling performance, which one of the two is better? I like both's aesthetics, but it seems like the h700i doesn't give me much room to upgrade.
The H700i cools slightly better, but the testing done was on air, and wont really be a factor since you're watercooling. The cases should perform the same in this situation.
If you put two 360's in the front and top, you should have enough cooling for one CPU and two GPU's no problem, especially if theyre 60mm thick. Though the only limiting factor might be that the H700I might not be able to fit the thicker RAD up top, I havent seen too many RADS up there that werent above 25mm.
