 So I'm thinking of upgrading my PC as it is getting a bit on the older side. I want to either upgrade my GPU or to a new CPU and Mobo . The problem is that I don't know which one would be better for the price or if it is even worth upgrading in the first place. I would like to know what you guys think would be good to upgrade and what is not worth to upgrade.. Also if you have suggestions on a different part that could be an upgrade better than what I listed, it would be nice. Thanks!
PLANS:
GPU Upgrade = 1080ti
CPU / MOBO Upgrade = I7 8700k + Gigabyte Z370 Aorus G7
SPECS:
CPU - Haswell-E 5820-k 4.2ghz
GPU - EVGA 980ti SC+ ACX 2.0 / Corsair H100i
PSU - EVGA SuperNova 1050g
Memory - ADATA xpg z1 ddr4 (24gb) (6x4)
Motherboard - Gigabyte x99 UD4
Case - NZXT S340
OS - Win10
https://linustechtips.com/topic/909568-pc-upgrade-help/
Yeah, that pc is totally outdated...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174541
For gaming, I suggest you upgrade the GPU because going from a 5820k to 8700k won't make a big difference in gaming, but changing the GPU will.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174542
Would you say the 1080ti is a solid upgrade? Or would you recommend something else.
Also, is there any cpu worth upgrading to or in this case would it be very minor with all upgrades.
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174573
I would say the only reason you should upgrade anything in your system is if you want to play games at 4k then the 1080ti is a good upgrade other than that your system is still high end.
System Specs
CPU: I7-5820k   MOBO:Asus X99 strix   RAM: 32gb corsair Dominator Platinum 2666mhz   GPU: Gigabyte G1 Gaming 980TI  PSU: Corsair RM1000i
https://pcpartpicker.com/list/mg7k2R
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174582
The 5820k is a 6 core and so is the 8700k. The difference is that the 5820k has 28 pcie lanes and the 8700k has 16. So the 5820k is technically better than the 8700k in some ways even though it's not as good of an overclocker. The 1080 ti will be a solid upgrade for you, especially if you're about to play at high refresh rates at a high resolution.
BTW what resolution and refresh rate are you planning on gaming at?
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174588
or at a lower resolution and high refresh rate
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174591
Only for 4k, really? Not sure but only reason I was thinking of upgrading is because of preformance in games currently on 1080p.
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174593
Right now I have 2 1080p 144hz monitors. If all goes to plan, I'm thinking of upgrading monitors later down the road.
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174597
The 1080 ti is good for 1080p 144hz, 1440p 100hz, and/or 4k 60hz (I'm just estimating).
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174607
Alright, thank you for the information. One last question, however. How big of a performance difference would there be between the 1080 and 1080ti?
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174619
A lot, check out this video:
https://linustechtips.com/topic/909568-pc-upgrade-help/#findComment-11174643
