You can see my current full build from my signature (i5-4690k,GTX 1070TI,8GB RAM).
I want to move to Ryzen platform, because I feel like my Haswell is a bottleneck in my system and it's old. My current CPU limits my possibilities to edit stuff in Premiere and also got into streaming.
I also have 144Hz monitor so I need those extra frames for games to look smooth. I usually play titles like R6 Siege, PUBG, WoW, Fortnite, GTA V, Witcher 3, Destiny 2 and probably will buy and play Moster Hunter: World. I sometimes (once or twice in week) edit with Premiere, Photoshop and Lightroom. I want to have ability to stream while gaming.
I want to buy new a MOBO, RAM (8GB is enough for now) and CPU. My current CPU cooler should be beefy enough, I just need to buy the AM4 bracket for it to fit. I want to be able overclock my CPU so the mobo should be sufficient. I heard that B350 mobos are good far that, right? I would like to have support M.2 drives for future upgrade. I also got the idea that maybe the 1700X could be good choise for me?
I live in Finland, here is a website which search for product from most of the shops at once. This should give a good image of prices here.
https://hintaopas.fi/
I would it to be as cheap as possible but still meet my requirements and stay relevant for longest time possible. I would say my budget is around 500€.
I really lost with all the Ryzen stuff, plz help.
EDIT: I'm also open for suggestions from Intels side as long as they meet the requirements.
https://linustechtips.com/topic/908981-help-with-upgrading-to-ryzen/
Ryzen isn't significantly better than anything else you could upgrade.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
21 minutes ago, That Minecraft Player said:
go watch the ltt video on should i upgrade to ryzen
That only made me even more confused....
My "problem" with current rig is that I can't stream during gaming, rendering is slow and can't get close to 144 FPS on popular new titles even with lowest settings.
What should I then do to help solve this?
Ryzen really doesn't overclock worth a damn, which makes the cooler fairly irrelevant, especially in your part of the world.
It was the most affordable way to get lots of cores when it came out, but Intel has since caught up. Also, Intel's tech is far more mature so it overclocks great (if you can manage the heat), and tends to have higher per core performance.
Going Ryzen now is mostly a price-related decision, or if you just really hate Intel. AMD have been discounting their products a fair bit recently with their second generation coming up.
That said, if you want high frame rates in games with Ryzen, you will likely need to buy high speed RAM (like 3000Mhz+). Obviously, that can cause price issues in the current market.
I'm happy with my B350 motherboard. Z370 is mostly if you want lots of USB3.1 ports, and more PCI-e options.
For gaming, you want up to 4 cores with the highest clock speeds you can afford. For streaming, you want that plus 2-4 more cores. Video editing likes high speeds but scales fairly well across cores, so that's flexible.
Simply put, the Intel 8700K is probably something you should look at, with the best speeds possible over 6 cores. Intel pretty much remains number 1 for gaming performance. If that's outside of your price range though, trying working back from that. There's no right or wrong answer, and an 8-core Ryzen 1700X would totally be a great choice for several of your needs, just not an outright winner in all of them.
If you want good hardware recommendations, please tell us how you intend to use the hardware. There's rarely a single correct answer.
I would rather suggest u to get an old used 4790k nd OC the hell out of it...
Also add in 8gb stick of ram
4790k goes around fr about €150
ND €50 fr 8gb ram..
Also u can sell ur i5 anytime....
But..if u hv made ur mind ND want to go ahead with ryzen...then this should be good part list fr u...
So Finnish €500 = $617.87...
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($168.60 @ Newegg)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($179.89 @ OutletPC)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Case: Fractal Design - Define Mini C TG MicroATX Mid Tower Case  ($59.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.49 @ Newegg)
Total: $637.74
Generated by PCPartPicker 2018-03-24 04:50 EDT-0400
Use ur existing 1070ti with it
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
I was actually thinking about getting 8700k, because I could sell my current setup and get some money from that.
I was thinking about something like this, any thoughts?
PCPartPicker part list: https://pcpartpicker.com/list/4Ft7r7
Price breakdown by merchant: https://pcpartpicker.com/list/4Ft7r7/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($332.90 @ OutletPC)
Motherboard: Gigabyte - Z370P D3 ATX LGA1151 Motherboard  ($89.89 @ OutletPC)
Memory: Kingston - HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($120.88 @ OutletPC)
Total: $543.67
Generated by PCPartPicker 2018-03-24 08:15 EDT-0400
9 hours ago, TrigrH said:
used 4790k and 8gb of ram
I'm not really fan of buying used stuff, so many scams these days, can't be bothered to risk my money.
ND €50 fr 8gb ram..
Total: $637.74
I don't need whole new system, I only want to change mobo,cpu and ram. But thanks for you suggestion.
Total: $543.67
U totally forgot about the cpu cooler ...
Also that Mobo is crap....get an ASRock z370 extreme4...it's an awesome Mobo....
Also got 16gb 3000mhz ram instead of 8gb 2133mhz fr just $60 extra
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($134.99 @ Newegg)
Total: $682.67
Generated by PCPartPicker 2018-03-24 08:25 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Total: $682.67
As I said in the original post I already have a cooler which I'm gonna reuse.
What makes that mobo "crap"?
Can you link that 16gb ram? :)
Alright..
As I said...get that ASRock z370 extreme4.... It's an awesome overclocking Mobo....got my 8700k to 5.1ghz with ease with this mobo.....
Here's the link to that ram..
https://pcpartpicker.com/product/3CdFf7/gskill-ripjaws-v-series-16gb-2-x-8gb-ddr4-3000-memory-f4-3000c15d-16gvkb
SSD TIER LIST
CPU - Ryzen 7 3700X
2 minutes ago, vexicus365 said:
Alright..
Okay, thanks.
Thar RAM is 100€ more here in Finland :/
