Hi guys!
I had been deciding these for a while now. I am a programmer as a hobbiyist and I wanted to buy a new PC. I was on a strict budget and came up with these. Will the following build suffice?
I am not a hardcore programmer but I may do some mediocore stuff after a year or two, so shall I be taking this laptop :
HP FHD Laptop
Or this desktop?
1. i3 8100
2. B370 Motherboard (upcoming)
3. 8 GB DDR4 RAM
4. 128 GB SSD
5. Corsair Carbide Spec - 1
6. Corsair 450W PSU
7. BenQ FHD 21.5 inch monitor
And I don't travel a lot.
All suggestions are welcome
Thank you
PC
CPU : Ryzen 3 2200G
RAM: G SKILL Ripjaws 8GB 2400Mhz
MoBo: GigaByte A320M - HD2
Storage: WD Green SSD
Case: Cooler Master
PSU: Cooler Master Elite 400W
https://linustechtips.com/topic/908437-pc-for-programmer/
The laptop has no SSD (and only a 5400 rpm drive) so will feel much slower.
I always prefer a desktop because:
  • Better price/performace
  • Better future upgrades
  • Can attach more monitores (I love my 3 monitor setup for programming)
Obvious downside of not being able to travel with it but as you say, you don't travel a lot...
It's personal preference...
https://linustechtips.com/topic/908437-pc-for-programmer/#findComment-11164107
Hey!
If you do not need the portability of a laptop do not go for it over a desktop pc. You will always get much better performance for the price with desktop. Other than that I would rather go for Ryzen 5 2400g/AB350 motherboard which would be similar price but more suitable for your needs.
https://linustechtips.com/topic/908437-pc-for-programmer/#findComment-11164116
1 hour ago, UnspeC5d said:
Hi guys!
HP FHD Laptop
Or this desktop?
1. i3 8100
3. 8 GB DDR4 RAM
4. 128 GB SSD
6. Corsair 450W PSU
Thank you
Currently coffee lake ND z370 is a pretty expensive platform...
This build will be more than enough fr ur needs...
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($98.90 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($103.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Case: NZXT - S340 (Black/Blue) ATX Mid Tower Case  ($37.00 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($33.98 @ Newegg)
Total: $463.64
Generated by PCPartPicker 2018-03-22 11:08 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/908437-pc-for-programmer/#findComment-11164429
First welcome to the programming club, it's an addicting hobby/lifestyle. Second, I would say like the others have commented that unless you need portability a desktop is the way to go. Third, I would look at a larger monitor or two monitors if you can swing it. Basically the ability to have code open on one screen (or window on a larger monitor) and be able to run/debug your application full screen on the other window is a life saver sometimes. Also just the ability to have both the code and a web browser for documentation and google searches on the screens at the same time is a lifesaver.
Just my 2 bits.
https://linustechtips.com/topic/908437-pc-for-programmer/#findComment-11164535
