galaxy note 3 idle battery usage?
Solved by beebskadoo,
Sounds normal, try turning off wifi during sleep. that tends to help. Make sure you check to see if there are any rogue processes that are waking your device.
Featured Topics
VinSen ·
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0
