CAT6A Outdoor Cable
Solved by W-L,
4 minutes ago, HeroXLazer said:Would I need to use anything else, such as conduit, with the Tough Cable or is the cable good as is?
Ideally you should always run cable within conduit to protect it on the exterior but you can just use tough cable and anchor it to the structure with cable hold downs as is.
Here are also some options if you want CAT 6A exterior grade cable.
