34 minutes ago, W-L said:
It shouldn't interfere with it, it just seems that as of right now it's physically not recognizing that the board has an RGB header itself.
Well, either the software is dumb or the header isnt working (which I doubt because it lights up red, just cant change it)
Idk if upgrading my BIOS or my cpu drivers would do anything, but I dont want to mess with that because its not my computer and if I fuck it up the owner wont be happy
Just to make sure this is the version you are installing onto the motherboard under utlities?
https://www.asus.com/ca-en/Motherboards/TUF-B350M-PLUS-GAMING/HelpDesk_Download/
Quote
Version 2.00.12 - 2017/08/23
ASUS AI Suite 3
ASUS AI Suite 3 V2.00.12 for Windows Win7 64bit &Win10 64bit.
EZUpdate EZ Update V2.03.17 for Windows Win7 64bit &Win10 64bit.
PPSU Performance and Power Saving Utilities V1.04.67 for Windows Win7 64bit &Win10 64bit.
System Information System Information V1.01.17 for Windows Win7 64bit &Win10 64bit.
LED_Control LED_Control V1.00.04 for Windows Win7 64bit &Win10 64bit.
FANRGBLEDControl FANRGBLEDControl_1.00.11 for Windows Win7 64bit &Win10 64bit.
File_Transfer File_Transfer V1.00.08 for Windows Win7 64bit &Win10 64bit.
That doesnt show up here
Edit: Found it
Edit: Found it
Expand Utilities, give that a go if you were not using the correct version of Aura for the board it will not function correctly.
