Replacing Cherry MX switches
Go to solution Solved by UndercoverBrother,
Completely possible, just need a solder sucker and a soldering iron, or a desoldering iron. Once you have all the switches you want out just solder in the new ones and it should work just as before.
Is it possible to replace Cherry MX switches with others, like Kailhs or Gaterons, on the same PCB? And vice versa.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/906947-replacing-cherry-mx-switches/
