45 minutes ago, reptep23 said:
does anyone know if the nzxt s340 elite supports micro atx motherboards?
Yes it does.
If you want more confirmation check out the product page https://www.nzxt.com/products/s340-elite-matte-white and go under the "Specification" tab then look at motherboard support.
https://linustechtips.com/topic/906671-help/#findComment-11146800
Just now, cl4nk said:
Yes it does.
do you reckon i should just get the ab350 pro4 instead of the m?
https://linustechtips.com/topic/906671-help/#findComment-11146801
The pro 4 has 2 extra ram slots, an extra m.2 slot, and more pci-e slots but also offers visual improvements, being that the motherboard will cover more space and that it has rgb leds on it and that will be very noticeable in the s340 elite. So unless you really need the extra slots you just need to decide if it is worth the extra money for the upgraded looks.
https://linustechtips.com/topic/906671-help/#findComment-11146805
