Fan Controller HELP
Go to solution Solved by WoodenMarker,
Have you set the cha_fan4 header to pwm in the motherboard fan settings?
So I have a fractal define r6. I has a fan controller in the back of the case. I have four 3-pin fans hooked up to it. and is plugged into SATA power. The manual says to hook up the main PWM into the CPU_FAN header on the motherboard but that fan is being taken up my AIO water cooler. I tried to plug it into another  PWM fan header (i.e. CHA_FAN4) but the fans will only spin at 100% which is somewhat loud. When I go into the BIOS, it doesn't detect the fans so it won't let me control the speed. Any ideas on how to get them to slow down?
https://linustechtips.com/topic/906627-fan-controller-help/
Try speedfan
Desktop benching:
https://linustechtips.com/topic/906627-fan-controller-help/#findComment-11146336
https://linustechtips.com/topic/906627-fan-controller-help/#findComment-11146353
34 minutes ago, Mikeak172 said:
the hub has both 3 pin and pwm headers
what do you mean?
Speedfan is a Windows software, mostly used because the BIOS doesnt give enough control on the fans.
Desktop benching:
https://linustechtips.com/topic/906627-fan-controller-help/#findComment-11146382
