20 minutes ago, Zassinus said:
Simple problem here. I wanted to use the windows intergrated solution to share movies and documents on my home network. When i try to set it up, both sides say that there are no networks and if i want to create one.
Both pcs are win 10 64bit
What are the steps you took to "set it up"?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/906369-file-sharing-problem/#findComment-11143840
Iopened the home network or whatever it is in english, it scanned for existing ones, found none and then offered me to set one up. It gave me a password and i chose what i want to share. ( videos, document, printers etc. ) When i go to join on the other pc it finds no other networks and also offers me to set one up...
https://linustechtips.com/topic/906369-file-sharing-problem/#findComment-11143989
I assume you mean a homegroup?  To create a homegroup you should set all your computer's network location to home in your LAN.  Windows 10 I believe automatically sets the network location to public, you can go to network in file explorer, it will scan for network clients, and a yellow bar will popup, you can click on this and choose to set the network location to home.
After that you can go to Control Panel > Network > Homegroup.  Here it should find homegroups in your network, and ask for a password. I'm not 100% sure but I wouldn't be surprised if different versions of Windows might have trouble all connecting into the same Homegroup.
https://linustechtips.com/topic/906369-file-sharing-problem/#findComment-11144069
If you're on the same home network, just add a new user on PC1 with the same credentials as the PC2 user. Then right click the folder/file you want to share and select [give access to] and select that users name.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/906369-file-sharing-problem/#findComment-11144180
