Hi everybody,
The Bugsplat says when PC2 crashes; Unable to alloc enough memory for pool 'Game' Please ensure that you have enough RAM installed
Though I have 16Gigs of DDR3, and the game in use only takes 4.3G at most, with 8 still available.
The GTX660Ti handles the game on low settings (1440p on 4k monitor), so 1550MB in use for the Vram, no issue there.
WoT runs just fine, CPU overclock is stable 4,3 Ghz
Core i5 3570k
MSI Z77Mpower
4x4GB Corsair vengeance White
AX760
MSI GTX660Ti
and some SSDs
Logitech G25
https://linustechtips.com/topic/906179-project-cars-2-error/
On 16-3-2018 at 4:32 PM, Technicolors said:
try reinstalling
or on Steam, verify file integrity
Already tried both those things :(
After long trying and wiggling I dropped down the stock OC settings from the 660Ti with -50MHz on the core and -50 on the memory, seems that one of those was the issue, temps are fine with 70 degrees... just like they were, something with power delivery?
https://linustechtips.com/topic/906179-project-cars-2-error/#findComment-11153323
