ummmm, everything is missing... thats just a blank slate...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130607
Just now, Rikudosenin said:
I feel it is a solid build. thanks for not trolling.
We CANNOT see your build.
It shows up as nothing because there isn't a link!
You need to post the permalink!
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130633
You keep posting the URL from the browser URL bar. That is NOT what we need.
We need this link:
Prior Build Log/PC:
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130640
Wow my bad. Thanks
No need to worry.
Go for i5 8400, its the same price or a little less. There are some z370 mbs for 90 but if u want to save some money just wait for non-z370 mbs. And I would recommend going for atleast 120 gb SSD you will never regret that.
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130652
The 6000 series is outdated and will give you far less performance.
I would suggest one of the following:
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($179.00 @ B&H)
Motherboard: ASRock - Z370M Pro4 Micro ATX LGA1151 Motherboard  ($106.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($164.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.49 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($354.98 @ Newegg Business)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case  ($69.49 @ Newegg)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($49.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Keyboard: Thermaltake - CHALLENGER PRIME Wired Gaming Keyboard  ($23.39 @ OutletPC)
Total: $1085.11
Generated by PCPartPicker 2018-03-12 09:02 EDT-0400
or
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($179.99 @ Newegg)
Motherboard: Gigabyte - GA-AX370-Gaming K5 ATX AM4 Motherboard  ($108.99 @ SuperBiiz)
Storage: ADATA - Premier Pro SP600 256GB 2.5" Solid State Drive  ($74.89 @ OutletPC)
Total: $1162.99
Generated by PCPartPicker 2018-03-12 09:05 EDT-0400
or
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($113.70 @ OutletPC)
Total: $1094.70
Generated by PCPartPicker 2018-03-12 09:06 EDT-0400
If you want to wait for GPU prices to come down then:
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($168.75 @ Amazon)
Total: $796.77
Generated by PCPartPicker 2018-03-12 09:04 EDT-0400
Prior Build Log/PC:
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130653
Just now, Shrijit jha said:
your build is perfect no problems there just add in a ssd if you can it really improves the performance although it is not mandatory
and also if you can go with i5 8400 with z370 mobo/ ryzen 5 1600 with b350 mobo that 6th gen is old now
https://linustechtips.com/topic/904995-i-need-help/#findComment-11130661
