that looks good. If you wait a while, the prices may go down, but NVIDIA said that that would only happen in Q3
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128429
Just now, MisterVince333 said:
Hello, I'm going to build my first gaming pc. Do you have any suggestions or do I have to change something?
Vince
Seems good. If possible :
1 - Try get a little better Power supply : EVGA G2 550 W per example,
2- Maybe ditch that HDD and buy a 500 GB SSD instead if you think 500 GB would be enough, if not, keep 250 with 1 TB HDD
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128432
Looks pretty good to me, but as a owner of the s340, I wouldn't buy it again. Don't get me wrong, it's a fine case, but knowing you can get a Meshify C from Fractal design for a little more, I'd get that. This is just a cosmetic decision of course :)
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128444
Why should the price go down?
Cryptocurrency "stability"
There is nothing that says that price WILL go down.
I say just buy it unless you can predict futur
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128445
Agreed, maybe a better CPU cooler as well.
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128455
use PCpartpicker. consider a bigger SSD and HDD as they will go fast. I have a medium game library and I am close to 2tb.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128458
1 minute ago, matus177 said:
Hey, that is almost identical to what I would like to build. But I want to go for Asrock extreme4 as mb. Can I ask you where are you from? Because u have got pretty good deal on that 1060.
I'm from Belgium, but the GPU is secondhand
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128467
What's the difference between the EVGA G2 550 W and my power supply?
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128505
@Crunchy Dragon What's wrong with my CPU cooler?
It's not the best cooler unless you're on a pretty tight budget. I personally would get a Dark Rock Pro 3(assuming your budget can fit that).
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128506
For anyone who plays multiple games, 500gb likely will not be enough.  If you plan on only playing ~3-4 games, 500GB may be enough.
I have several games that clock in at just over 100gb each.
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128508
Is it possible to just run windows on the SSD, and my games on the HDD?
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128516
Rating. Long term.
CX are "ok"
like I said, IF you can afford it, it ensure a more "safe" usage in the long term
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128518
You can search for "psu list" in the forum in the top search section of the website, and find the PSU list by TIERs
Again, if u can afford it $ then go for an EVGA G2
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128525
Yep.  Thats why I usually recommend 240-500gb SSD + 2tb or larger HDD.
I keep windows and 1-2 games on the SSD.  Things where loading times matter, like PUBG or ARK.
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128536
I don't see a difference... (watch this video:
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11128613
There is not much difference in games loading in most cases.
One of  the biggest one I see a difference in is BF1
If you want to save money, you can go 240 GB SSD for windows and all games video music on HDD.
windows take around 20 GB so you should have room for 1-2-3 games that you want to have flawless running
https://linustechtips.com/topic/904779-my-first-pc-i-need-help/#findComment-11129005
