If your current OS has detected and isntalled the drivers, then it won't make a difference. It would only help if the drivers didn't work on your PC and you were running with the MS Basic display driver.
Although, the speeds you're showing, makes me think it may be that.
Right click the start button and click Device Manager. Expand "Display Adapters", right click whatever is theren click properties. When the window opens, go to the Driver tab and screenshot it and post it here. If you can, switch to the "Details" tab, in the dropdown select "Hardware IDs" and then screenshot that too.
The GPU itself is just too slow to handle even those games.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Technically yes, because new OS can have worse support on old drivers. In reality, the GMA graphics is just too weak for software to help
Desktop benching:
Just now, pooooooor_gamer said:
I have installed drivers but from windows update (Any problem) ?
You didn't do the second screenshot properly, but it doesn't matter because you have the driver anyway. I think you really are just going to have to suck up those terrible FPS. You can try and hunt for a new version of the driver from the intel site but that's a pretty weak chip, so I wouldn't get your hopes up.
Prolly the system that’s too weak for the os. Not necessarily the card.
