Hi,
my name is Leon and im planning on Upgrading my System.
Im currently running:
Gforce 760 GTX
Intel I5 with 2x3,0 Ghz if i remember correctly
2x4gb ddr3
and some gigabyte motherboard
and planning to upgrade to:
ASUS Strix Z270F
Intel COre i5-7600K
Palit GeForce GTX 1060 3 or 6 gb (not entirely sure yet if the 6bg is worth it - opinions please. and im only buying one of those when they go back down in price they went from like 225€ to 350€+)
Would the new system be stable and most importantly would it bottleneck on a part.
Also would there be better options on some of the Parts.
I am only planning on replacing my Motherboard the Gcard and the Processor since the rest of my stuff like my ssd and hdd's and case and powersupply are still fairly new
Thx in advance
Leon
https://linustechtips.com/topic/904293-pc-upgrade-worth-it-or-not/
You would be bottle necked by the 3gb of VRAM on your GPU. It is well worth it to get the 6gb version. Also, why go on an older platform like the Z270? Why not go Z370 and a 8600k or something similar?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
If I was you, I would wait for GPU upgrade. Atm GPU prices gone off the rails. Unless you got friends in high places to get you 1060 at reasonable price, don't bother until new gen in released.
CPU upgrade looks nice.
Oh and get 6GB version, 3GB will bottleneck in modern games.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
you can probably keep everything appart from the GPU and be very happy with your upgrade. and either 3 or 6 will be huge and you'd barely see the difference
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
thx for the quick answers i guess i will wait for next gen gfx cards then because im not willing to pay more than the launch price for something thats just dumb.
as for the post from legacy: to be honest i still dont fully understand the difference between slightly old and brand new gen mainboards. like im not big into overclocking and dont know much about it but if i want to run my cpu and gfx card stock what would be the difference between the "old" and the "new".
the only thing i noticed about it is that the 8000 series have 6 cores at lower ghz rates but i think most games i run (CS:GO, LoL, the new battlefield if its any good, R6 Siege) dont run well on 6 cores. but like i said thats more educated guesses than hard fact :D
Leon
