Hello guys, I was wondering why I getting loud popping when I place my 2.4 and 5.ghz router near my subwoffer and/or my control speaker on my logitech Z506... if it is like 5 feet and closer, the noise is quite intense.
Any idea how to avoid that, because I would like my router on my desk near my speakers ...
Server 1 PC                                                   Server 2 PC                                               GEAR
CPU: Ryzen 7 1700                                                   CPU: Athlon 200GE                                               Keyboard: Logitech G Pro Keyboard
Motherboard: Aorus AX-X370-K7                            Motherboard: Gigabyte GA-A320M-S2H              Mouse: Logitech G900
CPU Cooler: Wraith Spire RGB                                CPU Cooler: Stock Cooler                                    Mousepad : Corsair MM300
Ram: Kingston 32GB 2666MHz                                Ram: Patriot Signature Line 8GB 2666MHz          Monitor: Acer XZ350CU Black 35" 21:9 144 Hz
GPU: Gigabyte G1 Gaming 980ti                              HDD: 1X WD Red 2TB                                           Headphones : Audio technica ATH-AD700X
HDD: 5X Seagate Barracuda 7.2k RPM 1TB            SSD: 1X128GB Samsung Evo                              Speakers: Logitech Z506 5.1
SSD: 2X512GB Samsung Evo                                  PSU: EVGA 100-W1-0500-KR 500 W1
PSU: HGC 850W Antec 80+ Bronze                         Case: Rosewill 2U Server Chassis
Case: Rosewill 4U Server Chassis
https://linustechtips.com/topic/904220-popping-noise/
its an interference problem. the wireless signal fucks with speakers sometimes.  GSM phones will do it too.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/904220-popping-noise/#findComment-11123764
Is there any way to solve this ? Let's say I want to change my router... I guess the problem will persist ?
https://linustechtips.com/topic/904220-popping-noise/#findComment-11123790
1 minute ago, elira said:
Put a big grounded sheet of metal between those two.
I think it would kinda look out of place on a desk ...
https://linustechtips.com/topic/904220-popping-noise/#findComment-11123821
you could put your router inside a Faraday cage
|Specs in profile|
https://linustechtips.com/topic/904220-popping-noise/#findComment-11123881
Um... yeah, I guess that would work (that’d end up looking like that weird set on “Enemy Of The State”, co-staring Will Smith). Or, @ethebigd , you can try this 2016 checklist posted by @SSL ... it’s a step-by-step guide for such noise...
...my 2 cents...
Edited by Guest
Movie reference...
https://linustechtips.com/topic/904220-popping-noise/#findComment-11124002
2 minutes ago, PrometheanCat2 said:
Um... yeah, I guess that would work. Or, @ethebigd , you can try this 2016 checklist posted by @SSL ... it’s a step-by-step guide for such noise...
...my 2 cents...
this might be a slightly better idea than mine.
|Specs in profile|
https://linustechtips.com/topic/904220-popping-noise/#findComment-11124011
