okay so i got the ek x3 250 res. but i cant use the mounts anywhere in my case. so i wanted to buy 2 of the ethereal singles from singularitys computers. but as i live in denmark and the only place they sell it in europe is in netherland i would need to pay a bunch of taxes. if i need to i will pay the price. but if you guys could find any other res to fan mounts(if you can in europe) i would be really happy
i spent $3500(23,000dkr.) on building my pc and i only play csgo on low settings..
:Specs:
CPU: Intel Core i7-6700  CPU: Cooler: H100i v2  GPU: Gigabyte GTX 1080 G1 Gaming  RAM: Corsair Dominator 3000mhz 16GB  SSD: Kingston 960 GB  Motherboard: ASUS ROG Maximus viii Formula  PSU: Corsair RM 750x 80+ Gold  CASE: Coolermaster H500P
https://linustechtips.com/topic/901223-res-fan-mounts/
You can get a universal bracket and some res mounts to bolt onto it.
https://www.watercoolinguk.co.uk/p/UNDesigns-Z2-Bracket-Fits-120mm-fans_735.html
https://www.ekwb.com/shop/ek-res-x3-holder-60mm-2pcs
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093263
Just now, W-L said:
i have the ones from ek but i cant put them anywhere. and it doesn't look like i am able to get the mount in eu-
:Specs:
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093282
Why not? You can just mount it to any 120mm fan or opening, if needed you can always drill and install the res holders.
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093290
if i install them on the fan it will hit the wall on the one side. and on the other site its not going to fit with the loop. there is no openings i can mount it to. so it needs to be in the middle of a fan or something like that
:Specs:
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093305
It's just a bracket you can drill a new mounting point exactly to the spot you need for alignment. The other bracket from Un design is also in the center which will work.
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093329
i cant get the mount in eu. i am trying to see how i will drill the holes. saves me alot of money. plus its not looking cramped
:Specs:
https://linustechtips.com/topic/901223-res-fan-mounts/#findComment-11093398
