Hello,
Does anyone know where i could get data that would allow me to recreate a roads gradients etc. For example does google earth store this info or are the cars that take the road images fitted with other data recording tools thats available.
Its to recreate real roads into a game mod without going to the road itself, in this case roads on the Isle of Skye.
thanks
i7 12700k @ 5.1GHz OC (EKWB) / Msi Edge wifi ddr4 / Asus TUF 3080ti (EKWB) / Acer XB327 270HZ, 3x LG 27GL83A-B 144hz, SONY KDL40D3000 Thermaltake P5 / 32gb Corsair Dominator Platinum 3600 / Samsung 980 pro 1tb NVMe ssd, Serbrent 1tb NVMe ssd,Samsung 850 EVO 500GB, Samsung 860 PRO SSD (raid), 2 TB Seagate HDDSeasonic TX 1000w titanium/ EK-FC1080 Ti GTX ASUS Strix RGB GPU Block, EK-Supremacy EVO, EK-CoolStream XE 360 [6x120 Thermaltake Ring fans], EK-CoolStream XE 360 slim [6x120 Thermaltake Ring fans],  EK-DDC 3.2 PWM Elite Edition, EK-RES X3 250 RGBMountain Everest custom with Sorbothane sound dampening / Razer Viper Ultimate, Logitec G502 , Logitec G Pro Wireless / Beardynamic DT1990 PRO with Litz wire full conversion to balanced, custom cable in Litz, Dakoni ear pads going through Topping E30 DAC to Singxer SA-1 amp/Sennhieser HD598, Sennhieser GSP 670, Custom Floor Standing Speakers in 5.1, Panasonic amp. Rode NT-USB on Rode boom.
https://linustechtips.com/topic/901121-data-for-mapping-a-road/
14 minutes ago, HOOTSMON said:
Hello,
thanks
It's unlikely the cars calculate that, because it's not really useful data to the regular person. At best you can get altitude points at fixed intervals or find a topography map, and compare your work with Street View.
https://linustechtips.com/topic/901121-data-for-mapping-a-road/#findComment-11092470
A car needs to have very expensive and specialized sensors for doing DEM, advanced GPS tracking and such. You can get close with open data. OpenStreetMaps have basic data which doesn't mostly have DEMs. Just XY lines. Google Earth has modeled their maps with NASA's DEM mappings.
I have bookmarked few sites that have open DEM files. You can get up to 30m accuracy (which might be same that Google Earth has, I don't remember). You can get higher res stuff with more digging, like 5m accuracy. But I think 30m is well enough. It means that there's elevation point every 30m.
http://www.webgis.com/
http://viewfinderpanoramas.org/dem3.html
And for OSM data http://osm2shp.ru/index.php?isLike
Do note that you need GIS software or DEM modelling software to work with these. I can recommend QGIS.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/901121-data-for-mapping-a-road/#findComment-11092551
Nice man thanks!
https://linustechtips.com/topic/901121-data-for-mapping-a-road/#findComment-11092567
