Spectre pros Led Connector?
Hello!
I have seen that Bitfenix spectre pro led have a different led connector, The only solution i found to get the leds start is to get Bitfenix Hydra pro which have those led headers.
But my questions is how to get those leds to start without any fan controller?, do the mobo have some led header or what=?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/90092-spectre-pros-led-connector/
here is the led headers in the middle http://s3.pji.nu/product/other/800/1621810.jpg
that stuff is the things on the fan controller!
just give them power cut up a old floppy connector or connect them to power led on ur mobo or hdd led
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
what?
Cmon guys! how do i do it? (read my first post)
connect it to any power sorce thats 5v or 3.5v from ur power suply or to the power led or hdd led header on ur mobo
That would all depend on the voltage of the LEDS and how they were wired up.
