so i have an
Acer Aspire E380
it has a Athlon II 64 X2 4400+ AM2
4X1 GB of ram
a GT610
and i'm trying to install a
Phenom II X4 B95
when installed it simply starts the fans and video card fans and psu
but no video output
I'm Assuming its bios version so i need help finding it [ its exreamly hard to find]
the motherboard is a acer ht2000 mcp61pm-am rev 1 A
I have tried alot of bios version including some modded but it always shows this after using AWDFLASH
bios lock string does not match
i have check to see if the bios boot protection is off [and it is] and i have checked everything relating booting and bios security to be disabled and nothing.
Plz help
https://linustechtips.com/topic/900233-cpu-upgrade-help/
Are you plugging your video into the motherboard or gpu?
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11083078
6 minutes ago, KGP-6401 said:
-snip-
I can't find any solid documentation stating that board can support a Phenom II CPU. So I'm going to have so you're out of luck.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11083088
i tried both motherboard and gpu
1 hour ago, airdeano said:
the b97 is AM2+/AM3
source: https://www.newegg.com/Product/Product.aspx?Item=1HD-001M-00006
the b97 will not work in AM2 mobos.. sorry.
correction its a b95. Sorry
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11083327
42 minutes ago, airdeano said:
ok thanks m8, also do you know of any cheap but good quality mobos for am3 then?
Edited by KGP-6401
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11083359
You can get a am3+ 970 chipset mobo still...that would be my recommendation
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11083487
Phenom 2 is an AM3, will support AM2+ motherboard but not AM2 only.
https://linustechtips.com/topic/900233-cpu-upgrade-help/#findComment-11085763
