I want to upgrade my graphics card but not sure which i should purchase any advice would greatly appreciated.
AMD phenom x4 965 black edition @3.5 ghz
gigabyte fxa 990ud5
Adata premier PRO sp900 64gb SSD X 2 (raid 0 boot)
MSi R6950 Twin Frozr II HD 6950 2GB OC edition
Corsair Vengence Ram  8 GB @1600
Coolmax ZX series 700W 80plus certified PSU
I was looking at possibly going with 2 660ti in sli.
also looking to liquid cool in the near future so I want to make sure I can get cards that I can find the proper waterblocks for. Thanks in advance for any help in furthering my build. :)
https://linustechtips.com/topic/90016-help-choosing-a-card/
I would say go for something like a GTX 780 or GTX 770, if you can find them the R9 280X or R9 290. I would also recommend a complete system upgrade. I say this because there maybe some bottle necking.
Quote me to get a reply!
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216630
Your CPU won't help you with 660Ti SLI, you would see a large bottleneck.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216631
Buy a single more powerful GPU rather than 2 mid range ones, you should only SLI two lower end GPU's if you can only afford them separately.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216635
And that dog shit PSU..................................
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216651
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216682
I know I fried my other one and got this one real cheap but im gonna upgrade it
how about upgrading to amd fx -8320 Vishera and 1 770
Awesome, but for the love of god, upgrade the PSU first, if you don't, i swear i will hunt you down and hang you by your breasts/testicles.
k?
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216720
HAAHAAHAA ok ok I need my testicles, Im gonna do one large purchase and yes a NEW PSu will be on it
Good man :)
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216733
A 650 watt psu will run 760/770 SLi without issues, just make sure it is a solid quality unit.
Antec/Silverstone/Seasonic/XFX/PCPower&Cooling/EVGA/Corsair are the main ones to stay with.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216759
Thank you
I would like to recommend the Coolermaster V700, it is a seasonic made PSU, so quality is assured, it is a fantastic unit, and is usually found for a good price.
If not, this is a monster for the price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207023
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216830
I'd grab an 8320, some cooling, PSU as recommended above, and then the best GPU you can afford (budget please?)
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216865
around $600
So after including CPU and PSU upgrades that should be enough for maybe an R9 290 once they come back down in price :) Then you could grab a second one in the future.
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216926
Le Bastardo+
Red Alert
https://linustechtips.com/topic/90016-help-choosing-a-card/#findComment-1216932
