Computer doesn't boot up but LED lights up
Go to solution Solved by BlueChinchillaEatingDorito,
Clear the CMOS, remove the GPU and see if the board will at least turn on. But I feel that your PSU is the culprit, it looks shady af. Looks like one of those cheap overrated ones.
Computer stopped working randomly as i was away. I do not know the reason for it to happen.
When i came back computer was already off, videocard was pretty hot and the videocard fan was stuck, BUT!
When I press the Power button, Power LED lights up, but none of the coolers start. Processor fan moves a little bit, but nothing more.
No signal on the display either. I tried to restart it, but it didn't help.
SPECS:
Motherboard: N68 - VS3 UCC (Asrock)
Processor: Phenom II, am3 socket
Videocard: Nvidia GTS450
PSU: QORI SuperPower 450w
Processor fan: Cooler Master (I don't know the model specifically)
P.S: Motherboard was diagnosed with "blown capacitors" but it still worked perfectly.
P.P.S: I don't have much money, so i can't fix it just by buying a new PC, etc.
https://linustechtips.com/topic/900159-computer-doesnt-boot-up-but-led-lights-up/
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
SPECS:
If I had to guess, I’d say your motherboard is dead, especiallly considering the age. A motherboard with a bad short will cause the problem you are describing. Worth trying troubleshooting thogh. Here’s a video that might help with general troubleshooting. Good luck!!
