Hey everyone,  I am looking for a motherboard which could support:-
1. two NVIDIA GTX 1080 Ti,
2.  2 TB SSD,
3.  i7 8700K,
4. and 128 GB 2133/2666 Mhz RAM.
A power supply to power this rig up, and a case to house everything inside. Also, any suggestions on what type of cooling should I use would be much appreciated.
Thanks!
https://linustechtips.com/topic/900088-extreme-overkill-performance-pc/
The 8700K only supports up to 64GBs of RAM.
Main PC: R7 3700X / Gigabyte X570 I Aorus Pro Wifi / Radeon RX 5700 XT / 32GB DDR4-3200 / 250GB & 2TB Crucial MX500 (in HP Prodesk 400 Case)
Laptop: R5 2500U / Radeon Vega 8 / 8GB DDR4-2400 / 500GB SK Hynix BC501 (HP Envy x360 13)
My little Server: i7-7700 / Asrock H110M-ITX / 24GB DDR4-2400 / Samsung 860 Pro 250GB & Seagate Firecuda 2TB / VMware ESXi 6.7
(Don't tell me i should Name them, i don't want to ^^)
Since you're already spending on parts that I consider quite silly, you might as well use a custom loop to cool it.
Thermaltake has the Core P series cases, Be Quiet has the Dark Base 900, Fractal has the R6, Cooler Master has the C700P, Phanteks has the Evolv and Enthoo (no particular order). Then there's Caselabs, In Win and Lian Li for more premium options.
For the PSU, there's the Prime, RMx/RMi, HX, AXi, T2, Dark Power Pro 11 and Straight Power 11 (no particular order).
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($339.00 @ Amazon)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($109.89 @ OutletPC)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($159.99 @ SuperBiiz)
Memory: G.Skill - Trident Z 64GB (4 x 16GB) DDR4-3200 Memory  ($848.99 @ Newegg)
Storage: Crucial - MX500 2TB 2.5" Solid State Drive  ($499.99 @ Adorama)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card (2-Way SLI)  ($1499.89 @ OutletPC)
Case: Fractal Design - Define R6 Black TG ATX Mid Tower Case  ($178.49 @ Amazon)
Power Supply: EVGA - SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($319.98 @ Newegg)
Total: $5456.11
Generated by PCPartPicker 2018-02-25 09:56 EST-0500
