Hi
There are two questions in this post and as this is my first post on this forum you'll have to slap me on the wrists and send me to the back of the queue if i'm breaking any forum rules or anything.
My friend has an ageing 990 FXA motherboard that we originally bought for Bulldozer before release.  We equipped it with 16Gb of RAM and a 1100T cpu.  He has a GTX970.  His games are really starting to suffer recently.  With prices going sky high at the minute i suggested maybe an x79 platform would help.  We can re-use the RAM from the 990 FXA 'board and i can get a i7-3820 from fleabay for about 50 quid.
My questions are as follows;-
Would the 3820 not bottleneck the 970 as much as the 1100T does now?
What are peoples thoughts on These generic x79 motherboards?
Your thoughts, people, would be much appreciated
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/899953-x79-side-grade/
yes
@herman mcpootis
Desktop benching:
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11080753
avoid any x79 board with 2 ram slots or no USB3. they're okay but the BIOS is pretty generic basic stuff.
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11080764
4 minutes ago, Daniel Z. said:
From people that have used those x79 boards before, they are ok, just very few features and bad quality. Not to mention the horrendous bios. They still work though
wrong quote?
Desktop benching:
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11080768
Well, at least you don't have problems with PC not booting due to putting the memory into the wrong slots.
Except for that, they might work fine because they are "bare naked" boards that only have the most basic features...
But either way, I'd recommend rather 115x socket - those are cheaper and lower power consumption. The X79 are rather high power in all regards.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11080795
Ok, Thanks i'll keep my eyes open for an 115x that'll take DDR3 ram
1 hour ago, Jurrunio said:
yes
Ok thanks, Would a i5/7 4x70(k?) sku be much better?  I'm only asking as i don't have much of a history with intel.  I've only owned three intel computers, my current 6600k, a PII 450, and an 80386)
Ok, thanks for the advice
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11080960
Quad core Haswell is the same, if not better at games compared to X79, but worse when streaming or editing, that kind of multi core stuff
Desktop benching:
https://linustechtips.com/topic/899953-x79-side-grade/#findComment-11081183
