Fan Control for H100i v2
Solved by partymarty,
I've used that same cooler for some time too.
My advice for decent control of the liquid cooler is:
1- Connect all your fans to your motherboard headers (or 2 fans on 1 header with a Y-cable)
2- Connect the pump to a fan header (or FAN_OPT header)
3- Go into the bios and create your fan profiles there (so 1 curve for the pump, I usually just set this curve to always run at 100% + 1 or 2 for the fans)
4-Deinstall Corsair Link
I really disliked Corsair Link for control over my pump/fans...
