My win8 computer is randomly waking. I haven't had time to check exactly what might be going on, but here's what I've got so far. I've googled it, and got no answer. I've tried using event log, which shows "Unknown cause" , same with powercfg. powercfg shows no wake timers, and I've disabled wake over lan. (I'd rather keep network wake on if possible) I've only been able to test it at night. Approximately 20 minutes after I set it to sleep, it wakes up. I'd love to actually use the sleep function.
tl;dr computer wakes up randomly, no known cause. Not mouse, not network, not wake timers.
https://linustechtips.com/topic/89890-random-waking-with-unknown-cause/
Hai
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
Hey,
It could be waking up via the network interface. There are "special" packets that can be sent via network which are accepted by the computer. Even if the computer is in sleep mode. you need to go into device manager and then go to properties of the network device you use. Then go to the "Power management" tab. make sure the "Wake on magic packet" boxes are unchecked.
That can be one of the reasons why the system wakes up for "unknown" reasons.
I hope this helps  ^_^
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
I just learned a few days ago that sometimes my mouse can power it up after shutdown. Just learned today that if I press any key on the keyboard it will power on from shutdown. I've checked the BIOS, these settings are off.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
Hey,
Elven
That option for me is grayed out. Actually it isn't there but the closest one is grayed out.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
Certain programs can cause the system to wake.
Things like an AV updating itself, something else updating itself.
Best thing to do is clean up the system startup, disable things from turning on that don't need to be running.
Check the system power management and see if there are any odd options.
Test the mouse, unplug it. See if it still happens.
Ethernet adapter can wake it. There are options to set it not too.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
