Hello i built my new pc 1 month ago and 1 week ago i purchased new gt 1030. When the gpu arrived, I installed it and i received no signal. Tried everything and nothing. I was thinking about BIOS update (my mb is asrock h110 hdv r3.0), but i was scared to do it. My only option was to return the gpu to receive a new one. My local store told me that the gpu is working and i'll receive it tomorrow. Also i did BIOS update after i returned the pgu. Can someone tell me why the first time the gpu was not working (no signal). Could it be from the BIOS Update ? I know that this can happen if the mobo is really old, but this is a new mobo h100 series. I really don't know. Please someone tell me because i'm gonna blow my head. Also my PSU is Corsair VS450.
https://linustechtips.com/topic/898498-problems-with-gt-1030/
You did connect the monitor to the GPU right?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/898498-problems-with-gt-1030/#findComment-11066106
Assuming you plugged everything in correctly, I have experienced the same issue but with very old hardware (a Q6600 build) and I found that updating the BIOS fixed it. I dont know if this applies to whatever parts you are using because everything varies and you almost definitely have newer parts (I can only assume, you didn't say what they were) but this worked for me :)
https://linustechtips.com/topic/898498-problems-with-gt-1030/#findComment-11066129
Yea i know that bios update can fix things but the fcking mobo is new 2017 if im right.
https://linustechtips.com/topic/898498-problems-with-gt-1030/#findComment-11066153
4 minutes ago, Qucd said:
Absolutely. I know how to connect my monitor to the gpu. Heck i built a PC.
Ehh, just asking. It's always good to start with the basics.
Main System: Phobos
https://linustechtips.com/topic/898498-problems-with-gt-1030/#findComment-11066176
