So I fix phones for a living and today I was working on an iPhone 8 Plus, just a screen replacement, and in the process ripped the ribbon cable for the front camera. The guy is pissed and I can’t find the part anywhere. Just slightly freaking out.
Gotta be more careful with those cables. It takes me an hour to do a repair because of how careful I am with removing those cables.
https://www.ebay.com/itm/iPhone-8-8-Plus-Facing-Front-Camera-Sensor-Back-Rear-Camera-Lens-Flex-Cable-/232570715460
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
I supposr the "Dr." Bit in you username should have dropped a hint, but I wasn't aware you fix iPhones yourself.
My eyes see the past…
My camera lens sees the present…
On 2/19/2018 at 4:00 AM, huilun02 said:
Are you an Authorized Service Provider? If not, maybe that's why you are having difficulty performing repairs. Its actually very easy as long as you are an Authorized Service Provider. So you should definitely apply for it, very easy to join;
Once you are certified, repairing iPhones will be a breeze. Definitely the most user serviceable phones out there. ;)
I used to work for apple, I knew about this but didn't really think I was big enough to do it. I'm not the owner but I'm the manager and repair tech, the only person that works there. Would I be able to get the certification and still run the shop?
