ultra bugdet GPU HELP!!!
Go to solution Solved by Jay Deah,
Another option to consider is changing your case and swapping your components into a standard ATX case. This was you can use any GPU you like.
I personally have an OptiPlex 7010 SFF running inside my antec case. You’ll want a <$5 adapter for the power switch and system fan from moddiy.com (dell use proprietary connectors) and you may lose your front panel usb2 and headphone/mic jacks if you don’t fancy re-wiring the connectors.
hi guys !
i am looking for a LOW PROFILE budget GPU under 150 dollars i am planning to buy "gt 1030 low profile" just need more suggestion under the budget with low profile cards and will they be compatible with my system and please tell me will 1030 or other card under 150$ can run games like PUBG,CS:GO and other game at medium settings !!??
My pc is old "dell optiplex 9020 SFF" which i use for CAD mainly but do gaming now and then so thats why !!
SYSTEM:
image.thumb.png.aa389a76a7bad623cc3d10a853a3ca4c.png.63502d157e6c7d1181b376f08ea3fa17.pngimage.thumb.png.522137998046fc57ddbfe6f9963d994d.png.aaf37c33a68f77a06daabd93be177cb3.png
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/
3 minutes ago, Ali.007 said:
The Only GPU you can buy, and worth buying right now is the GT 1030, so the choice is pretty easy
You just need to make sure to update your BIOS if possible before installing.
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11058663
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11058692
I can run any gpu if i swap the case ?? With that motherboard !?
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059428
That gpu can run those game i mentioned??
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059430
Just look up benchmarks for the GT 1030, but it's your only option right now anyways
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059447
No, you would have to make sure your power supply can handle it and has the PCIe connectors.
However, you can get low profile 1050 and 1050 Ti cards that don't need extra power connectors. Those would be much better for gaming than a 1030 and better value for money as well.
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059456
Except they're either out of stock or marked up 50%-100%
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059462
I have a GT 1030 low profile from MSI.  It is a rare one that has displayport, not just hdmi.  So if you plan on getting a better monitor in the future, I'd go with that one.  Not sure how it would perform on games, but if it is your only option, it isn't a bad one.
Link to the MSI GT 1030 with displayport https://www.newegg.com/Product/Product.aspx?Item=N82E16814137139
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059566
you need a standard ATX case with a standard ATX power supply (the Dell power supply wont mount easily in an ATX case).
https://www.amazon.com/Computer-Cases-Add-Ons-Computers/b?ie=UTF8&node=572238
you use the existing dell motherboard, it will fit in a normal case. the only non-standard things are:
POWER/RESET SWITCH - Use an Adapter Cable from MODDIY or crimp the cables yourself
CASE FAN - Either keep the DELL Case fan or get an adapter cable from MODDIY (or leave it out, it warns you on boot but still works fine)
FRONT_PANEL (HDAUDIO+USB2) - plug in the existing front panel and leave it inside the case, or bridge 2 pins on the connector (or leave it out, it warns you on boot but still works fine)
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059626
7 minutes ago, Apepa said:
The 1050 2GBs don't seem to be affected. They're not suitable for Etherium anymore.
Still starting at $150 for that tier of card on the part picker
https://pcpartpicker.com/products/video-card/#c=379,380,416,395&sort=price&page=1
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11059970
Well, what can I say, the situation is worse in Murika than it is here in the UK.
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11060030
I am a Pakistani and here finding a low profile 1030 was hard AF !! But thanks for the suggestion
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11060393
I have to change the power supply if i go with a big case cause my current one will not fit so i have to have a new big power supply and 1050 is 2gb and 1030 is also 2gb whats the difference ?
https://linustechtips.com/topic/897830-ultra-bugdet-gpu-help/#findComment-11060477
