My computer keeps crashing after being up for only 10-15 minutes. Before the freeze occurs my SSD is at 100% at almost no load. There is nothing that is working or using the ssd or at least according to the task manager. I bench marked my SSD and it was at 100% during the benchmark and it did not crash. (AD SSD BENCHMARK). All this happened after a windows update and i have reinstalled windows but kept my personal files. And what i need help with is to figure why my computer keeps crashing is it my PSU or my CPU or even my PSU that is causing the failure.  The Blue screen error code is CRITICAL_PROCESS_DIED. Both my PSU and SSD is about 3-4 years old.
SPECS:
PSU: Be Quiet PURE POWER L8 630W
GPU: GTX 970
 5a898781f3d8c_as-ssd-benchSamsungSSD84018_02.201814-53-51.png.8e5383bbabf93e324675dddbad03f349.png
https://linustechtips.com/topic/897783-help/
Reinstall Windows.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/897783-help/#findComment-11058196
